Recently aquired a Sony unit as above.
It pretty much plays anything you throw at it....SVCD as well as VCD on CDR all layers I have tryed...
HOWEVER....when I play a CDR that has been encoded with CCE (DVD2SVCD) There are slight pauses in the picture at random intervals...it can be quite annoying although still watchable.
When I play a SVCD encoded with TMPGE it works perfectly. I also have a Lennox stand alone DVD player...which plays everything faultlessly....encoded by either perfectly
Was wondering if anyone had any sugestions about any CCE settings I might alter that might correct this problem since this is obviously not a CDR related issue more a MPEG stream compatibility issue with the Sony player.
DVD2SVCD produces a far better result and is easier to use than a TMPGE solution in most casesalso gives the DVD chapters automatically which is nice
Results 1 to 1 of 1
Sony DAV-DZ360WA
By pablogarciavera in forum DVD & Blu-ray PlayersReplies: 0Last Post: 9th Dec 2009, 17:15 -
Not sure about the Sony DAV-HDX265
By onenonly in forum Newbie / General discussionsReplies: 2Last Post: 12th Sep 2009, 16:34 -
Sony dav dz 260
By vladc64 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Dec 2008, 19:11 -
sony dav-dz230
By greekys in forum DVB / IPTVReplies: 1Last Post: 6th Dec 2007, 17:50 -
Sony DAV-DZ230
By TCEkryten in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Dec 2007, 16:59
