i mean - there is Nero Express and Nero Burning Rom, what's the different between this two modules?
can i burn the DVD file (VIDEO_TS) with the module "Make DATA DVD"? is it possible?
thanks for the help!!
Nero Express has a Wizard type interface for beginner users. Although you can probably make a working DVD with the data DVD selection (since a video DVD is ultimately a data DVD, UDF 1.02-iso bridge with a particular file structure), it would be better to pick Nero's Video DVD template in the regular Nero Burning rom program, since this makes sure the files are in proper order (allocation) etc. Pick from File menu - new and then pick Video DVD. Then just drag all the files into the VIDEO_TS folder it supplies in the template.
Burn authored VIDEO_TS as UDF or CDFS (or RAW) file system format?
By PCat in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2009, 17:33 -
How to burn a mkv file to dvd with dual audio and subtitles with nero.
By drkcloud in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2008, 04:48 -
Using Nero Ultra: How Do I Use Video_TS Folder ---> DVD
By MacPCConsultants in forum Newbie / General discussionsReplies: 6Last Post: 28th Nov 2007, 07:16 -
Burn an already authored DVD-Video folder(VIDEO_TS)
By jain30 in forum Authoring (DVD)Replies: 2Last Post: 12th Jul 2007, 10:02 -
Is it better to burn a VIDEO_TS folder or a MPG file?
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2007, 17:54
