    Mar 2007
    Hi,
    I have read through several How To for Dvd Decrypter and DVD shrink but haven't found the answer to what I want to do. My wife is throwing an 80's pary in a few weeks and she wanted for the lack of a better term a Mix DVD of the best scenes from 80's movies to play during the party. Is it possible to just rip single chapters from DVD and burn them onto a DVD to play continously? I know that I can rip a DVD to my HD and then edit it using Nero but I haven't figured out how to get it to the DVD to play except as individual chapters and it will only play one chapter at a time. I can't figure out what I am doing incorrectly. Any help is appreciated.
    Dec 2006
    Here,where do you think?
    Hi zuke! if your clips are DVD compliant, then run them through DVDShrink in Re-author mode to merge and backup to one movie...
    best of luck!!!
    See this, http://www.dvdshrink.info/compilation.php
    " Who needs Google, my wife knows everything"
    Mar 2007
    Hey t0nee1 thanks for the reply. Should I be setting DVD decryptor in a cerain way to make sure they are DVD compliant?
