I am new to the whole copying of DVD's and I am having problems lol. The files I have are all in AVI format and my DVD player won't play them. So I got hold of a converter and converted them into DVD format and then put them onto a DVD disk. I have both DVD-R and DVD+R because I didn't know which format I needed. When I put the files onto DVD-R as a dvd file they play on my DVD player but the sound and the video are out of sync. Am I doing something wrong? Do I need to put the files in a particular order for them to play correctly?
Closed Thread
From start to finish which programs did you use? It would also help if you posted a Gspot screenshot of the original AVI file that went out of sync when you converted.
He's a liar and a murderer, and I say that with all due respect.
Originally Posted by Vampyreholic
A) Use AVI files suitable for conversion. Avoid AVI with VBR audio, for example.
B) Use a good converter. If reading lots of guides (found under CONVERT left) is not your cup of tea, try convertx2dvd. Or better yet: Get a player that plays AVI. The price is about the same.
/Mats
I've using Nero. I think it's Nero 6 as it came pre-installed into my PC when I bought it 2 years ago. I've since found out that it doesn't matter if I use DVD+R or DVD-R as both play on my DVD player but both play out of sync.
I have noticed though, that on Nero, you get 2 folders and it tells you to put the files in the video folder. Am I supposed to put the sound files in the sound folder?
Forget about Nero. All it's (possibly) good for, is to burn stuff to disk. Nothing else.
I repeat my advice from previous post: either use convertx2dvd, or get a player that plays AVI. The latter is the best choice.
/Mats
Unfortunately, buying a new DVD player is not an option for me right now.... if I could afford a new dvd player, I'd be buying the DVD's from the shops rather than getting them illegally lol
You are in breach of the forum rules and are being issued with a formal warning.
This site is not about getting help with illegaly obtained material. Read the rules again.
/ Moderator mats.hogberg
Here in the colonies, we can get the Philips DVP-642 for $60 US or less. I'm sure similar players are available in the UK.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 14:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
