Are there any freeware tools which can be used to determine what write speed was used to burn a disc? I have a DVD+R disc which was burned a long time ago and I want to know what speed it was burned at.
Results 1 to 13 of 13
Zakkkkkman
No. Out of curiosity: Why would you like to know?
/Mats -
Every so often I want to know this for different reasons, but all usually having to do with troubleshooting. In my latest case, I noticed that one of my DVD drives was burning a particular 16X DVD+R at 6.4X (according to display from the software I was using). I was a little suspicious, so I thought I would check some discs I burned last month using the same method. I am trying to determine if this is a new problem, or if it has always been that way.Originally Posted by mats.hogberg
Does anyone know if the burn speed is written to the DVD?Zakkkkkman -
You could look at the top of the disk & see what speed the disk was. It should say so. Chances are it was written at the top speed.
Unfortunately, that is exactly what I am trying to test. I want to know if it REALLY was burned at the maximum speed.Originally Posted by handyguyZakkkkkman
I believe there was a registry tweak for NERO that allowed you to view in realtime the actual burning speed while burning - Unfortunately once the disc is burnt you cannot get that info, as it is not stored. Sorry.
OK, thanks. At least I know now, so I don't waste time trying to find it.
Zakkkkkman -
To show recording speed in Nero:
1. Start-> Run-> type Regedit
2. Go to "HKEY_CURRENT_USER\Software\ahead\Nero - Burning Rom\Recorder"
3. Go to Edit-> New -> DWORD Value
4. Rename "New Value #1" to "ShowSingleRecorderSpeed"
5. Click on it and select "Modify"
6. Now set the value 0 to 1 -
What does this do?Originally Posted by archaeo
Which Nero program?Zakkkkkman -
That registry edit is used with Nero 6; it forces Nero to show the actual real-time write speed during the burn rather than just the selected speed.
...Which wasn't the point of this thread, which was how to determine from an already burned disk, what speed it was burned at.
/Mats
How can I increase DVD/Blu ray write speed?
By gsingh13 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Jul 2011, 22:47 -
multi LG Gh22np20 write speed issues
By mistermofo in forum DVD & Blu-ray WritersReplies: 5Last Post: 6th Jan 2010, 19:37 -
determine which playlist to take
By KlintIstwood in forum Blu-ray RippingReplies: 2Last Post: 14th Apr 2009, 16:01 -
Finding out write speed
By BrokenOne in forum DVD & Blu-ray WritersReplies: 2Last Post: 31st May 2008, 02:40 -
problem with write speed of dvd burner`
By mr-scarface in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Sep 2007, 13:58
