I'm using vdub to capture using huffyuv and gives me this message once i reached 4.078gigs. i tried to capture again and still i get the same message. does anybody know why? i have 32gigs of free space. capture settings:
29.97fps
41000 khz audio
preview mode
352x240 res
Sounds like you have FAT32 drive (vs. NTFS) which has a 4gb file limit. You need to enable multi-segment capture in VDub. Take a look in the faq (to the left) for how to do this. I recommend setting segments at either 1.9GB or 3.9GB (ie. short of the avi 2GB limit, and the fat32 4GB limit).
Parameter is incorrect
By xstoanurag in forum ComputerReplies: 2Last Post: 16th Jun 2011, 21:43 -
Parameter Incorrect?
By The Monkees in forum ComputerReplies: 3Last Post: 18th Mar 2010, 18:41 -
What parameter in Gspot or MediaInfo shows if AVI will play in DVD player?
By jimdagys in forum Video ConversionReplies: 6Last Post: 19th Apr 2009, 02:58 -
Incorrect Output File Sizes With AutoGK
By H3rEye51nRoam in forum DVD RippingReplies: 14Last Post: 27th Oct 2008, 11:37 -
converting avi to wmv in wme9...incorrect parameter?
By sixinsouth in forum Newbie / General discussionsReplies: 3Last Post: 28th May 2007, 13:45
