is there a decent dvd player that will play .avi files without needing conversion? i will spend the $800 for it if it means i dont have to spend 5 hours converting and burning a freakin jerry springer show for my friends =p
sorry if theres a thread on this already
and thank you so much for any input!
Results 1 to 14 of 14
There are a lot of dvd player's that will play Divx/xvid avi files burned to cdr & dvdr.
Just look around they're not hard to find.
Not sure what's up there but down here you can get them pretty much anywhere that they sell dvd players, electronics retailer, bestbuy, abc warehouse has one for around $50.00.
And 5 hours converting
What are you using ? A 75mhz with 32mb of ram :P
ConvertXtoDvd -
<<<--- DVD Players, file type divx/xvid, search. Done.
The guy who started this forum is quite correct -- after market consumers should not care if AVI is a container or what it contains. We need a player that supports a wide range of current codecs without scratching our heads over which ones or trolling through this sort of forum for hours.
Originally Posted by kush
My requirements are:
1. want to be able to play as many video / audio formats as possible, expecially: fast and flawless divx AND XVID and hopefully other MPEG4 AVI formats as well flexible audio codec formats too including AAC, AC3, MP3 (VBR/CBR), etc. I've learned that the MediaTech chip set is the one to go for, so it would be nice if it had that.
2. need flexible and problem-free subtitles including .SRT, .SUB
3. needs coax video output because I have an old tv but hopefully also some more current connetions in case i later upgrade.
4. has to be region free or have an easy hack
5. should play PAL and NTSC
6. it would be nice if it had a USB 2.0 connection to hook up a flash drive at a decent speed (but not absolutely required).
seems like simple requirements. I have a Philips DVP 642 now, but it is useless for .SRT, doesn't play .SUB, and completely unpredictable with XVID. Other threads have mentioned GMC problems etc.
The best option in terms of specs seems to be: RJTech's RJ-1800DVX. It has everything I want (including listing GMC in specs), plus as a bonus is also 110-120 V and "multiregion" (i assume that means region-free) out of the box. However it seems it is using Sunplus rather than Mediatek chipset (and doesnt support QPEL)
http://www.rjtech.net/desc_RJ-1800DVX.htm
The model 800DVX is Mediatek and handles BOTH GMC & QPEL but has no USB:
http://forum.ncix.com/forums/index.php?mode=showthread&msg_id=892488&threadid=892488&f...id=0#msg892488
But everyone here says RJ Tech models are crap and break:
https://forum.videohelp.com/viewtopic.php?t=273873&highlight=rjtech
However some positive comments:
https://forum.videohelp.com/viewtopic.php?t=279873&highlight=rjtech
(however, there is nothing in this forum about the 1800 model and those posts are about earlier models)
The OPPO line doesn't seem to be possible because it doesn't have a coax video output. (Really, my tv is hooked up with an RF modulator and audio goes out to a component stereo system):
http://www.oppodigital.com/dv981hd/index.html
The Pioneer 490S it seems I'd have to buy pre-region free for more money, which is ok I guess, but it is also limited in that it has no USB support. I also can't find very convincing specs that it will play all the formats (especially the subtitles) that I'm after:
http://www.220-electronics.com/dvd/pioneer490.htm
https://forum.videohelp.com/viewtopic.php?t=304296&highlight=dv970hd
I'm hessitant about the whole Philips line because of my bad experiences with the DVP642 and their tech support being clueless about subtitle files:
https://forum.videohelp.com/viewtopic.php?t=235493&postdays=0&postorder=asc&start=30
I suppose the Philips 5960 is an option but for the problems above, and also the fact that the USB is 1.1 ! (how useless is that for video?)
I did the following search, and came up with 32 players, but mostly by manufacturers I've never heard of:
https://www.videohelp.com/dvdplayers?DVDname=&cdr=1&dvdr=1&Search=Search&vcd=1&svcd=1&d...Submit2=Search
Any pointers appreciated, including from those who have this new RJ-Tech model. -
RJ Tech just came out with 2 new DVD players: RJ900 (USB) and RJ 1900(USB+card reader) . Both play PAL/NTSC/multiregion and have no problems with subtitles. Check out http://www.multiregiondvdplayers.net/
Originally Posted by cx420ns
,i won't mind having to go buy a new one,kiddin walmart man $50 as someone posted above
Originally Posted by redrocklobster
1) GMC (Global Motion Compensation). Even the few devices that claim to support really only support 1 warp point. Tests have shown that the players that claim to support 3 warp points actually will not play the files. Generally it's best to avoid this as a result.
2) QPel (Quarter Pixel)
3) Packed bitstream. MPEG4Modifier can remove this without re-encoding.
4) Video bit rates higher than 2000 Kbps can be a problem on some players.
5) Use of AC3, PCM, or DTS audio can be a problem unless the video bit rate is 1400 Kbps or less. CBR MP3 is generally OK with higher video bitrates. VBR MP3 may have sync issues in playback with any video bitrate.
6) Large files (greater than 2 GB) may not playback due to use of FAT32 file system.
7) Use of custom quantization matrix (very rare, but it happens) may also be a problem.
For best results, files that avoid all of these things will almost certainly play back. Do note, however, that AVI containers allow a variety of audio formats and use of exotic audio formats such as AAC and OggVorbis are rarely supported on DVD players. -
If you need to convert or reencode, try AutoGK. It has a setting to create "standalone compliant" files.
Aside from that, you won't find a player that supports ALL avi files. There are just too many encoding options. For best results get a Divx or Divx Pro certified DVD player. But you will still need to "fix" some files.
Note that most of the files created for TV use (ie: TV shows) will play fine on most Divx players. It's all of the misc avi files that people collect on their PC's (and meant for PC use) that cause most of the playback problems. So if you want to view all the crap you download to your PC, you need to expect to spend some time to make it work.Google is your Friend -
I am waiting to check out one of these:::
http://www.popcornhour.com/onlinestore/
I especially want an easy player that would also play MkV files...
I'll let you know how it works when I get it! 8) -
My two cents - I recently bought a Toshiba TV/DVD/VCR combo unit which claims to support Divx-encoded avi natively. Well, not only does it play Divx avi's, it plays Xvid as well, & flawlessly...plays VCD/SVCD perfectly too. I am very happy with my purchase.
Stiiv -
Just thought I might add, I have downloaded various "videos" from the internet and burned them to disc to save hard drive space. Out of curiosity, I put one in my PS3 to see what would happen and it plays them all flawlessly.Even the ones that are in folders or in folders that are in folders. Plays blue ray disc and rock band too as a plus!
PS3 also has wireless networking to pull video, audio (for those with nice surround theater systems), and pictures from your puter. Networking, however, is more work than I like to mess with so, no idea on watching avi straight from the puter, but I don't see why it wouldn't. My opinion, you can't beat the price for the capabilities. Price I believe is still $400-$600, but I don't think the cheaper ones have wireless and have a smaller hard drive(40GB). Compare b4 u buy. Too expensive to buy a second one for my bedroom though.
I bought a Philips 3960 from Walmarts for $40. The model numbers change a bit, but try one that with 39, like a Philips 3962
I love mine, I can get an entire tv season on a DVD and toggle thru them
Hope this helps -
shadowolph - Welcome to the forums, but we generally discourage people from digging up old threads from months ago and adding to them. The original poster last posted to any forum here on March 19, 2007 with his 2nd post in this thread. We appreciate you trying to be helpful, but basically the people who cared have long since stopped looking at this thread and the original poster hasn't logged in since March 29 of last year. This is why we discourage people from doing what you did - it's just a waste of time in most cases to add to old threads. I'd advise as a general rule that if there hasn't been a post in a thread in more than 2 months, unless what you have to say is really and truly critical it's probably best to just let it alone. I am not trying to condemn you but to help you to become a better forum member as I'm sure you don't know that we discourage posting to old threads.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
avi on DVD-player
By cro987 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Aug 2011, 18:53 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Avi dvd player
By imkool in forum DVD & Blu-ray PlayersReplies: 6Last Post: 13th Feb 2008, 20:15 -
AVI help on a portable dvd player
By benrkay in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jul 2007, 10:20
