Results 1 to 12 of 12
What We Do In Life, Echoes In Eternity....
The best comparison is:
DVD Shrink, RipIt4Me, DVDFab Decrypter, ImgBurn = Free, work well together and work on any DVD out there.
DVD2One = Not free
How they compare, don't know. Shrink works for me, even with Vista.
If you want better quality, try DVD Rebuilder. Also free.
Someone out there has probably done a comparison for quality, but I doubt there would be much difference. DVD2One may be a little easier to use. -
Originally Posted by redwudz
& who wrote the description for DVD2one
With this tool you can make movie-only and full disk copies for personal use on a single DVD-Recordable. You can also copy double sided or several DVD-Videos two one DVDr.
I know shrink is no longer updated, and that DVD2one is not free. I was just curious if perhaps dvd2one had changed the process which it uses to compress, from one of their earlier versions. Thanks for the replies guys
What We Do In Life, Echoes In Eternity.... -
Yeah i never really bothored to mess with anything else, shrink alway's worked great and looked fine.
Used to use nreo recode years ago but it never seemed as good as shrink so shrink it alway's was....
If it's not broke, don't fix it :P -
I understand the author of dvdshrink was hired by Nero and is responsible for the recent versions of Nero Recode.
I haven't seen any comparisons of the current version of recode with DVD Shrink and other similar programs.
It seems faster than DVD Shrink. I wonder what any else thinks. -
I have occasionally used DVD2One version 2 on DVDs Shrink rejects.
The quality is okay. Better than earlier versions.
It's tons faster than Shrink.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
I'll post the page below once again.Pretty good explanation of how DVDShrink works. BTW, the purpose of Deep Analysis is to more accurately allocate the requantization. If a transcoder is very much faster than Shrink, I would suspect it comes at the cost of accurate allocation.
http://forum.doom9.org/showthread.php?&threadid=63587Pull! Bang! Darn!
Newer FFDSHOW versions screw up audio sync for me - why?
By TigerSoul in forum Software PlayingReplies: 7Last Post: 26th Mar 2010, 16:26 -
Not being able to rip BD with newer versions of DVD FabDecrypter6.2....
By cal_tony in forum Blu-ray RippingReplies: 6Last Post: 13th Nov 2009, 06:47 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
May need newer software
By codeman in forum Newbie / General discussionsReplies: 2Last Post: 14th Nov 2008, 08:29 -
Newer Binaries?
By theorik in forum ffmpegX general discussionReplies: 0Last Post: 30th Sep 2008, 02:39
