Hi all,
Can any recommend a website that holds good qualitysound effects, like, doors slamming, heart beating, car horns, aircraft flying past and so on.
I need some good effects to go with a new project using adobe audition 2 and premiere pro 2.
Thankyou in advanced
josel
i am taking a guess you want them to also be free? but since you did not state they needed to be free. i use SMARTSOUNDS with the QUICKTRACKS plugin. this plugin is for premiere pro so you can use the sound effects as if they were built in as part of premiere pro. they are good quality also 44k 16 bit stereo i belive. do not quote me but i belive they also come with ok/decent quality copys as 22k that are indeed FREE and the plugin itself is free.
for a video demo of this GREAT sound effects plugin goto...
http://www.wrigleyvideo.com/videotutorial/tutdes_ppro_quicktracks.htm
cheers. -
Help! When I render a video in Adobe After effects, theres no sound!??!?!
By Devilsadvocate in forum EditingReplies: 4Last Post: 21st Mar 2012, 10:02 -
How do I Rip sound effects and music separately?
By tapir in forum DVD RippingReplies: 9Last Post: 19th May 2010, 02:04 -
After Effects error: opening sound component (-2166)
By santolina in forum EditingReplies: 0Last Post: 24th Apr 2010, 09:36 -
How to find moive sound effects?
By squeejiboo in forum Off topicReplies: 2Last Post: 29th Aug 2008, 08:04 -
Sound Card Compatibility with After Effects CS3 Issue...
By Angelus22 in forum EditingReplies: 1Last Post: 28th Oct 2007, 08:20
