Closed Thread
    Mar 2007
    Yea like i need help. I have a photodex video and i need to convert it to mpeg so i can play it in windows media player...or is there software out there where i can capture the video and save it as a media player file?
    Thanks, help would be appreciated!
  2. Member p_l's Avatar
    Montreal, Canada
    If you still have the project on your computer, you can just open it again and produce it as an mpeg directly.
    If all you have is the show as an executable file, you may need to use some kind of screen capture program like Camtasia or CamStudio.
    Mar 2007
    thanks!
