  1. When you use a VHS tape as source you sometimes get that white flickering line at the bottom of the screen. I was wondering if there's a program that can correct this? Maybe by simply removing the bottom few pixels of the AVI? (Or some more ingenious approach)
  2. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
    USA
    It's probably VHS 'head switching' noise. If it doesn't show up on the TV, I would just ignore it. If you blank it out, you will need to re-encode.
    And welcome to our forums.
    Nov 2002
    London, UK
    I would have removed it just before encoding. Like someone said already, if it is already on the DVD then you would have to do it all again.
    I tried some of those flicker filters for virtualdub last night, and all they did was make things worse. I reduced filter by increasing a temporal noise filter. It normalized the flicker, albeit at a cost of making the image look a bit more "plastic". But plastic was less obnoxious than high-speed flicker.
  6. Member Marvingj's Avatar
    Apr 2004
    Sounds like a Macrovision protected commercial VHS tape that they are
    trying to prevent from being copied.
    On a 16mm film home movie transfer?
    May 2006
    I have an in line unit called a Macro Terminator II to remove Macrovision on VHS tapes when backing up my originals. It is the only unit that I found actually works. Good luck in finding one though. They have not been manufactured for years. Used to be made by a company from Atlanta. Maybe ebay.
    I also use a Hotronic AP41 TBC to clean up any signal I'm working with.
