I have a project with the usual 2 x BUP 2 x IFO and 9 VOB's, I tried to burn it to disc with NERO 6 (OEM). and it turns out too large. Is there a compresion option I am missing that would not decrease the quality of play back ?
On the other hand is there a tutorial that would guide me into splitting the files to 2 DVD"s , where I could convert the menu so each disc would have a menu ?
Beer is good !
How much too large? If this is a DVD file you have created, there's probably not much you can remove, such as unwanted languages, etc. You could try DVD Shrink for quick and easy, but you will have quality loss if the file is far oversize. Another option would be DVD Rebuilder and re-encode it. This would be better if it's quite a bit oversize.
Or the last and slowest way is to comvert it back to a MPEG with VOB2MPEG and re-encode the whole thing.
Or you may be able to split the VOBS up without re-encoding, but someone else would have to give you tips on that.
spit 4 hours wmv into 1 minute parts
By pribl in forum Newbie / General discussionsReplies: 1Last Post: 16th Jun 2011, 04:45 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
spit MVK 12 Gb in two dvdr-9 and then play on blue ray in loseless quality
By siopilos in forum Authoring (Blu-ray)Replies: 1Last Post: 8th Feb 2009, 18:31 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49 -
Can i compress a
By YOURCONNEXX in forum Video ConversionReplies: 4Last Post: 9th Dec 2007, 12:03
