    Jan 2002
    Mexico City
    I need to convert an Mpeg Audio file, to mp3!!!!!
    How do i do that!!!!!!!!!!!!!
    The Mpeg file can only be open by real, not even music match can open it!!!!!help me !!
    the files ends wit .mpega!!
    Please help me
  2. Originally Posted by SANTIAGO2002
    Please help me
    get a mp3 encoder
    Jan 2002
    Mexico City
    Where can I get that????
  4. try downloads.com they have on the first page at the top something about converting your files to mp3. or browse for it from their site. i don't know how good encoders they are though.........
    May 2001
    Maryland, USA
    Try using TMPGEnc to convert the MPEG audio file to a .wav and then convert the wav using an MP3 encoder.
    Load up TMPGEnc and load you mpeg audio file under audio source. Then select the "Audio Only" radio button. Now click File and you should see "Save as file" or "Save As" (not sure exactly what its called because I do not have TMPGEnc installed on this machine). Then select the Save as Wav option. Now encode the wav file using an MP3 encoder like LAME.
    Hope that helps.
    Jan 2002
    Mexico City
    Thanks N0SoopForU Im downloading TMPGEnc , when I've change them I'll post it here 8)
    Jan 2002
    Mexico City
    Thank You VERY Much It worked perfectly...
    take care everyone see ya later
    San
    May 2001
    Maryland, USA
    Great! I'm glad to hear it worked for you.
