I have burned VCD's (ez 5.0 platinum, Windows ME)that play on my computer when associated with windows media player but they will not play on my DVD player (Sony DVDPS 560D) took the disks to a store and tried to play on other DVD player with no luck. Called Roxio and there "support" said if it plays on the Computer it should play on player. Need Help badly PLEASE
JAdrianse,
It seems that your DVD Player Unit only accept "Silver Layer" brand for CD-R and "All Layer" brand for CD-RW as informed in DVD Player list. It plays VCD.
If you want to know the list what about all your DVD Player Unit play, go to the left side of this page click "DVD Players" and make your consult OR TYPE:
http://www.vcdhelp.com/dvdplayers.php?DVDname=sony+dvp-s560d&Search=Search&list=0
I hope help you.
I HAVE THE SAME DVD PLAYER AS YOU THE ONLY 2 BRANDS OF MEDIA i HAVE FOUND TO WORK ARE THE MEMOREX PLATINUM RW WHICH I PREFFER AND THE SILVER LAYER PRINKO'S THERE THE CHEAP ONES FROM COMP USA ONLY 50 PACKS NOT THE 100 PACKS THEY ARE A DIFFERENT BRAND BUT I WOULD STAY WITH THE MEMOREX, THE PRINKOS HAVE PROBLEMS WHEN YOU GO TO COPY THEM AND WHEN YOU PLAY THEM IT SOUNDS LIKE THE DVD PLAYER IS WORKING REALLY HARD.
The verbatim datalifeplus highspeed (4x-10x) CD-RW will play on the Sony S560D. Only other one I've tried is Fujifilm CD-RW. Doesn't work. The verbatims are hard to find. I'll have to look for the memorex ones!
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
dvd won't play on player but will on computer
By bubbadss in forum Authoring (DVD)Replies: 9Last Post: 28th Apr 2010, 02:49 -
MPG files play fine on computer, no audio on DVD player
By kenimpzoom in forum Newbie / General discussionsReplies: 9Last Post: 16th Feb 2010, 14:07 -
DVDs play on computer but not on DVD player
By audax in forum Authoring (DVD)Replies: 21Last Post: 16th May 2009, 06:54 -
Why do HD dvd play chopping using computer versus smooth on blueray player
By CX7 in forum Newbie / General discussionsReplies: 10Last Post: 6th Nov 2008, 17:23
