Hi folks, im totally bamboozled, i`ve allready spent some serious man hours on this project and im still at square one? Basically im trying to transfer some VHS`s to DVD! The only video i have is a portable TV/Video combi and beleive it or not it only has one scart socket and nothing else! Cannot manage to configure so my DVD recorder can copy, anyone help me? I have all the leads etc, is there a tutorial for numptys like me?
Scart is a 'both way' interface so should have video and audio out as well as video and audio in. However, not all pins are used by all devices. A DVD player (not recorder) for instance will not have the input pins connected.
If you are using a fully wired (21 pin) scart cable it should work and the video from your VCR should be output to your DVD recorder. It may well be that the scart on your TV/VCR is only wired as an input (so you can plug a DVD player into it) and the output pins aren't connected. If this is the case, you need a different VCR..... -
i have tried so many different combinations i thought something was wrong? it may be easier to borrow someones VCR i guess, thanks
combi tv/dvd region codes
By robin1983 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Feb 2011, 17:21 -
VCR/DVD Recorder Combi... To Meet My Needs? (NTSC/PAL)
By NowNow in forum DVD & Blu-ray RecordersReplies: 0Last Post: 26th Jan 2011, 15:09 -
a vcr/tv combi to separate dvd recorder
By omg in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2009, 13:53 -
Combi Tv Dvd Unit problem
By Soixante in forum Off topicReplies: 0Last Post: 12th May 2008, 13:26 -
Bush combi Video + DVD recorder
By debrag in forum DVD & Blu-ray RecordersReplies: 1Last Post: 31st Dec 2007, 11:11
