I filmed and edited a film in high definition using final cut on my college campus. I exported the movie to a quicktime file, and burned that file to a DATA DVD (not DVD-video, just the quicktime file). However, I can not get that file to play back on my PC at home. It will open in quicktime, but it will only play the audio. I know that the video is there because in the quicktime file properties, it shows the video data (resolution, frame rate, etc). I have played HD quicktime files on my computer before, and i know for a fact that my computer can handle it (core 2 duo 6400).
I have heard that Final Cut exports HD video to a special "EVO" format, so I went to http://www.ensight.com/downloads/cat_view-6.html to download EVO QuickTime Component and DirectShow Plugin for Windows but it still will not play. What should I do?
Gspot shows this: (HDV2 codec?)
you need to flatten the QT file before playback on a pc .. dont use h264 is you plan on editing or something on the pc also ..
the blackmagic codecs are cross platform compatible and lossless"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Flatten, yes.
My guess is the Blackmagic codecs would leave him with a file too large for easy transportation--would have to be split up. That's why I didn't suggest it. I do agree with the need to keep in editable form, if possible. Just assumed it wasn't feasible anymore, so "make do with most bitrate efficient" of distribution codecs.
Guess we'll have to hear more from the OP...
Scott -
ohh i see. i wasn't planning on editing it any more. i thought it was just a standard quicktime file. guess i'll have to re-export it once school is open agian.
Might be possible to change the "codec atom" from "HDV" (or whatever it actually is) to "MPG2", and then it might be possible for the MPEG2 codec (that Apple sells) could be DL'd and installed to decode it (if it supports HD profiles)--with a PC.
Final Cut Pro, gives me GENERAL ERROR when exporting to Quicktime
By Huntr777 in forum MacReplies: 8Last Post: 30th Sep 2011, 14:26 -
Missing audio in mpg files from Sony Camcorder in Final Cut and Quicktime
By Benhermies in forum MacReplies: 3Last Post: 2nd Feb 2011, 22:13 -
AVCHD viceo with .MTS ending cannot be read by Quicktime/ final cut express
By johsch in forum ffmpegX general discussionReplies: 10Last Post: 26th Nov 2008, 14:01 -
Final Cut won't open
By Tom in HD in forum MacReplies: 5Last Post: 5th Jun 2008, 15:23 -
final cut file to upload onto blip
By marinebc11 in forum MacReplies: 1Last Post: 1st May 2008, 10:13
