If I were to stop using my refillable carts (these ones have sponges) and store them away for say a year, and then decide to use them again, would they actually work. Would the dried ink cause problems?
Results 1 to 10 of 10
What We Do In Life, Echoes In Eternity....
Get one of those vacuum 'Seal a Meal' machines from K-mart or Target. Handy for other stuff, too. No guarantee that that will keep them from drying out, but it's about the best you can do.
Here is the thing, the carts are already empty, but there is still a illt bit of ink inside the carts. I don't really care if that ink dries, what i was actually wondering about is after the ink dries out, will these carts work again? These carts are the ones with sponges. I kow, I should have bought spongeless, but I got them before I read about that.
What We Do In Life, Echoes In Eternity.... -
Most inkjet inks are self soluble, ink residue can be dissolved in the ink. It make take time and effort but you could remove dried and caked ink.
Some ink refill kits include a cleaner fluid, this would work as well.
The sponges will of course make the process more questionable, since they my dry out and then shred.. -
I actually had to use my old home made refill carts that had been stored for almost that long. My tubing on my CIS had a hole in it and I had to order another one. Until then I had to brake out my old refill carts. I was surprised that I didnt have not one problem with them. I refill them and went right to work. The were not in a bag or closed off in any way.
What I have done with a cartridge with plugged nozzles is to soak the nozzles or ink output openings in a bowl of warm water with some dish washing liquid. It may take a few hours. Isopropyl alcohol will work also, but I like the water method. Once the chunks are dissolved or softened, dry them off and the cartridges should work again after a cleaning cycle or two.
I don't know if oil based and water based inks are still both used, but the alcohol may work better with oil based and the warm water and soap better with water based inks. -
thanks guys
I actually just bought a brand new r200 on ebay, (previous printer was also a r200), and have run out of refill ink for the smart carts. However I do now have the epson originals, and several generic brand ink set that expire in 07, so I figured i better use them, before they do, other wise it was a waste of money buying them. So that's why I plan on storing my empty refillables, until all my other carts are gone
Store Sales
By vhelp in forum ComputerReplies: 2Last Post: 26th Sep 2010, 17:46 -
How to store CD and DVDs
By mysts in forum MediaReplies: 10Last Post: 8th Jan 2010, 13:21 -
How do you store your videos?
By kelemvor in forum Newbie / General discussionsReplies: 5Last Post: 8th Jul 2008, 17:34 -
Ink question for refillable Epson R220 cartridges
By Mahime in forum MediaReplies: 3Last Post: 14th Jan 2008, 20:54 -
Does Canon use chipped carts?
By ranchhand in forum ComputerReplies: 17Last Post: 15th Jul 2007, 15:00
