Hey there,
Anyone there can tell me if there are facts now, there says that the 112 is as good / better than the 111 ?
Crelle..
Results 1 to 20 of 20
check out the PIONEER FORUM at Cdfreaks.com. I own both of those drives and they both burn very well with the dvd media that I use.
Well, what I can tell you is the Pioneer 111 is pretty much perfect in all regards, both reading and writing, as well as build quality and media burn quality and media support.
That is important.
All models can vary a bit. While Pioneer is almost one of the best 3 drives, the 111 is probably their best drive to date. I need to buy another one.Want my help? Ask here! (not via PM!)
The 112 is proving to be a very awesome drive for me. I don't have the 111 to compare it to, but it smokes my 108 in all respects.
http://shop3.outpost.com/product/4806290;jsessionid=j5OI1DNF8wWFDcBCJxvsgQ**.node1?sit...H:MAIN_RSLT_PG
Going off topic a bit Newegg does have the SATA PIONEER 212 available as well.
http://www.newegg.com/Product/Product.asp?Item=N82E16827129009
I do like the 112 drive as it burns 12x-16x very well with VERBATIM & TY media. -
I have the Pioneer 710 (111d) and it's fabulous both read and write. I would expect the 112 to be good as well but you never know, I'd go with the proven 111. As someone mentioned, checked the CD Freaks Pioneer forum, there's probably more user reports and testing been done on the 112 there.
The BEST BUY website now lists a Pioneer DVR-1810B which I am assuming is the retail version of the OEM DVR 112 ... is that correct?
Originally Posted by FulciLives
http://www.4shared.com/file/11145216/c1d94c12/Firmware_and_utility_for_A12J112L.html
The instructions on how to flash are included in the zip file. -
111 is a great burner for me. I have 2 of them anyway.
Time to get a 212, its not out here.... -
In Stock:
39.50 shipped
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=171029
39.00 shipped
http://meritline.stores.yahoo.net/pioneer-dvr-111d-16x-dvd-burner.html -
Originally Posted by [_chef_
DVR-111 can still be found under the ASUS nameplate.
ASUS DRW-1608P3S = Pioneer DVR-111 (with crossflash)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135083
Originally Posted by Richard_G
I own the 111 in black and am looking for another but can't find black so I am considering the 112. Would like opinions on 111 vs. 112. Really like my 111 but can't find it in black, should I buy a beige 111 or is the 112 (which is available in black) just as good as the 111? Thank you for your comments.
Thank You,
GolfNut -
Originally Posted by golfnut
onesickpup thank you for the repsponse. What is the difference between the 111 and 111d, any idea? Thanks.
Thank You,
GolfNut -
DVD RAM support which if you crossflash to the 111L you will get anyway. But al least it is available and in black.
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 06:02 -
pioneer having problems with 112 drives
By aedipuss in forum DVD & Blu-ray WritersReplies: 2Last Post: 24th Dec 2007, 06:50 -
Should I get a Pioneer 112 or a Liteon 20a drive?
By heman31 in forum DVD & Blu-ray WritersReplies: 3Last Post: 12th Dec 2007, 11:05 -
Pioneer 112 or 112D?
By blacktooth in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Aug 2007, 17:09
