Results 1 to 10 of 10
    Feb 2007
    When I try to play a MVK file it plays in 2 little squares in the top of the player and the screens seem to be the bottom left or right squares of the screen, what does this mean?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Have you tried installing/reinstalling the latest mkv codec?
    Google is your Friend
    Feb 2007
    I tried installing the latest combined community codec pack.
    Are these the right codecs or are there other ones i need?
    Try latest haali media splitter together with ffdshow.
    Feb 2007
    I tried those 2 and they still play the same way
    Feb 2007
    It's the oddest thing i tried all the codecs and nothing, Mkv files wouldn't play for anything in media player clasic so on a whim i downloaded VLC player and they play perfectly.
    Why do they play right in one player but not the other?
  7. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    VLC uses its own (internal) codecs, not the system's, so that implies something isn't set correctly with the system codecs. Did you already have ffdshow (and/or Haali's splitter) installed before Baldrick suggested the latest versions?
    Feb 2007
    i tried those and it is still the same
  9. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Yes, but I was asking if you already had them installed before Baldrick suggested trying the latest versions of each. What player(s) were you using to play MKVs that had the problem?
    Feb 2007
    i was trying windows media player clasic from the combined community codec pack
