I’ve been looking for a remote control for my JVC HR-S3600U S-VHS player.
The exact replacement remote model number is the LP 20303-009 (which was apparently supplied with the following models: HR-S3600, HR-S3600U, HR-S4600, HR-S4600U, HR-VP674, HR-VP674U, HR-VP675, HR-VP675U, HR-VP676, HR-VP676U, HR-VP770, HR-VP770U, SR-TS1U.)
I’ve had good luck in the past with getting remotes to work from different units within a brand. For example, for the Panasonic AG 1980 S-VHS player, I found that a Panasonic remote LSSQ0263-2 works (a remote originally supplied with some run of the mill Panasonic VHS players).
I found a JVC remote that looked pretty close, the LP 20034-013, but no go. Perhaps the remote has to at least be at least one with the MBR designation on it (multi-brand remote, that is, one that will control a T.V. cable box, etc).
I’m assuming that any of the LP 20303 remotes (regardless of sub-number) will work, but perhaps this is a false assumption too.
I’ve also had no luck getting a Sony universal remote to work with my HR-S3600U.
Any tips or shared knowledge would be appreciated.
My 3800 has a LP20303-015
My 7965 (PAL) has a LP20878-016
My 9800 has a LP20465-007
I don't know where my SR-V10U remote went.
Anyway, these all work on each other 100%
I randomly pick up any JVC remote to use.
This is actually a bit of a pain in the butt, too, because one remote will basically light up the whole room and change ALL the VCRs in range.Want my help? Ask here! (not via PM!)
Hey, You might want to see if you can find a replacement/original from sites that sell just that. I found a couple while searching google that may be useful:
I hope that helps
JVC SR-V10U remote control
By bigvlad12 in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2011, 14:49 -
Remote control of computer?
By cwb in forum Media Center PC / MediaCentersReplies: 9Last Post: 29th May 2010, 19:29 -
Which Media Players has File Search function via Remote Control
By suijaypao in forum Media Center PC / MediaCentersReplies: 0Last Post: 27th May 2010, 18:56 -
Remote control JVC Everio GZ-HD10U camcorder.
By 872156 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Jun 2009, 17:51 -
Do I need a remote control to program TBC/3R etc functions in JVC HR-S7955?
By leon43 in forum RestorationReplies: 1Last Post: 14th Dec 2008, 08:04
