Probably audio has been converted from mp2 to LPCM audio, which takes up lots & lots of space. But almost 4 GB audio, sounds like too much even so...
/Mats
Results 31 to 42 of 42
What is your audio file format, it sounds like LPCM. Convert Audio to AC3 or MPA with lower bitrate rate (224 or 192).
i changed the audio formatting and the dvd is still playing up! when i go to play all, there is no sound and to add insult to injury after a few seconds of playin it says the media is not readable, whats that all about
any suggestions? -
What is the media (media ID and brand would be good) ?
Have you tried DVD Info Pro's speed test or Nero Drive Speed on the disc after burning ?Read my blog here.
when using dvd lab pro's quick lab encoder, do i use the orginal source to get the audio or would you extract that from the file i have just encoded?
guns1inger- the media used is a Phillips DVD+RW-120 min video (extended play 240 mins)-4.7GB -
okie dokie, but do i use the orginal source ( the copy my freind gave me) to get the audio or would you extract that from the file i have just encoded?
horray!
the DVD now works perfectly... well in specific machines i have anyways, only problem i have now, is that the fast forward and rewind doesnt work at all, what could be the problem?
thanks in advance
steve -
could someone please explain why my homemade dvds created by dvd pro lab doesnt work in my phillips DVD recorder & my toshiba multi dvd/vhs machine ? it works partially in my playstation 2, only things is, it stops playin after the 1st scene, due to an error of some sort
please help
steve -
Poor source (video or audio), poor burning, poor media, poor players. Without having access to the source files, or knowing what brnad disc you are using, it is impossible to say. I know that all the discs I have created with DLP play in a variety of players, but I use either full or half D1, not VCD res, and good quality encoders. I also burn to good quality discs.
Read my blog here.
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 05:52 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
DVD Lab Pro compilation problem
By JohnCPun in forum Authoring (DVD)Replies: 11Last Post: 8th Jan 2008, 17:31 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
