I have some divx files that are 700mb in size, which is a bit much.
I'd like to halve the size of each of the divx files, and change the AC3 sound to 128kbps mp3, which will hopefully not lose a lot of quality in the video.
How do I do this? Cheers
Also, I'd like to do the same with some other files, but they are in mp4 files...
AutoGK to lower bitrate DivX/XviD is the easy solution.
How long are your 700 mb files? (Timewise)
/Mats -
That could work, but beware that halving the file size (=halving the bitrate) essentially means halving the quality. 128 kbps mp3 should be OK, and may gain some sizewise (depending on AC3 bitrate)
/Mats -
I was hoping most of the file size would be reduced by changing AC3 to mp3
AGK works mostly, but not with mp4, any ideas? thanks.
Install ffdshow and avisynth if you don't have them. Then make an avs file (just a text file with an avs extension) and type in it DirectShowSource("full directory of file")
Then try opening the avs file in AutoGK. If that doesn't work try regular GordianKnot
ripbot-made mp4's ... reducing bitrate
By zero7404 in forum Video ConversionReplies: 4Last Post: 22nd Nov 2011, 18:41 -
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 07:30 -
Limitingand reducing out file size
By TJF in forum Video ConversionReplies: 6Last Post: 7th Feb 2010, 09:25 -
Help with reducing size
By gepetto in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 13:17 -
Reducing Quicktime size
By Mark V in forum MacReplies: 3Last Post: 22nd Aug 2007, 22:24
