After a lot of stumble i got TMPGenc to work right...
and then i tryed to burn the VCD with Nero 5.5.6.4....
it finished...
But when i play it on my standalone DVD-player..
it's "pauses" about every 30 secs, it just freezes for about 1 second, and then continous.
Also there is an irritating skip about every sec. (not very noticable, but still you can see it
The .VCD is good (i think) because it plays very well on my pc.
I think there's a problem with nero.
i burned it twice, with the option (once you draged the file to the burning window.... right mouse click on the file):
properties.....
Pause after track: 5 / seconds...
i also tryed:
Pause after track: 0 / seconds...
both had the same irritating problem...
I can tell you this, encoding isn't a 1,2,3 thing...
it comes with a lot of swearing and cursing!!!! %(^$#@
i hope that someone can help me.....
singed,
a guy in high need.....
have you tried loading the vcd template in tmpgenc and then encoding the file? the vcd template is a pretty standard complaincy
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 11:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 13:40
