Would like your suggestions for any inexpensive drive for ripping to hard drive only. In particular one which will read and rip problem discs with minor scratches would be preferred. Thank you very much for your suggestions. Also include where to buy your suggestion if you do not mind. Have a great day.
Results 1 to 14 of 14
Thank You,
GolfNut -
How inexpensive are you looking for? Burners are now about $30 at many online outlets.
In my opinion, the only way to buy a DVD-ROM is, in person, on a clearance table, because the shipping costs bring the cost over the value. -
Anythink under $50 is good for me as long as it is a good ripper. Any suggestions? Thank you.
Thank You,
GolfNut -
Dvd burners are so cheap now. I'd suggest buying a dvd burner since the prices are inexpensive. Get a LITEON 18x or 20x spd dvd burner which can rip at 16x spd for single layer media & 10x spd for dual layer media.
http://www.geeks.com/details.asp?invtid=LH-20A1P-DO-BLK&cat=DVD
http://www.newegg.com/Product/Product.asp?Item=N82E16827106043
If you really insist on getting a dvdrom check out Ebay. I've gotten most of my LITEON 167T & TOSHIBA 1612/1712 dvdroms from Ebay. -
older NEC models. anything BUT the 7xxx series which Sony has put their 2 cents into its design.
The last few comparisons I've seen, all of the major manufacturer drives perform about equal. So it boils down to brand preference or price.
Google is your Friend -
Hasn't it been said more than once that burners don't make good rippers? I've always had a DVD-ROM drive for reading and ripping and a burner for burning. For ripping, either Liteon or Asus. I recently had a scatched disc and found that the Asus DVD-ROM drive ripped it with less errors than a Pioneer burner.
Richard_G, I agree with you, that is why I ask for DVD Rom recommendations for "ripping only", still unsure what to buy for ripping at this point. I have a Pioneer 111L which I am quite happy with for burning but both my Plextor 708 and Pioneer DVD ROM are starting to give ripping errors, just worn out I think.
Thank You,
GolfNut -
The Asus I currently have seems pretty good but normally I use Liteon and have never had any problems with them. Most people I've seen recommend them too. They seem to be pretty universally available, so just see what you can find in your area.
Thanks Budz, Richard_G, and all others for your info and recommendations. I think I will go for a Lite-On.
Thank You,
GolfNut -
There is also a big differnce in ripping between brands/models. I have an older Pacific Digital (rebadged Lite-On) burner, that I use for all troublesome discs. It doesn't RIP as quickly as my newer NEC or Pioneer drives, but it can read discs the others cannot. I also have an old Hitachi dvdrom and a Lite-On dvdrom, but they aren't any better with problem discs than my newer burners.
Anyway, without knowing the exact make and model of a known good "ripping" drive and then being able to test it against the new drives, it is all a matter preference and opinion.Google is your Friend -
Welx! If you're going with a LITEON, I'd strongly suggest getting a dvd burner. The dvdrom & dvd burner read spd are both the same. To pay about $10.00 more for a dvd burner with the same read spd as a dvdrom is worth it.Originally Posted by golfnut
I agree, I'd go with the DVD burner over the DVD-ROM, all day! The LITEON burners are known to be great rippers.Originally Posted by budz
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 09:33 -
Blue ray ripping on dvd rom
By skorpinok in forum Blu-ray RippingReplies: 1Last Post: 4th Dec 2010, 09:31 -
CD \ DVD ROM not seen in Windows
By lacywest in forum ComputerReplies: 1Last Post: 16th Oct 2009, 10:19 -
dvd rom problem
By ieh4f in forum DVD & Blu-ray WritersReplies: 2Last Post: 13th Jun 2008, 03:49 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 08:55
