I'm using Nero Ver 7.
I'm having two problems, and both are intermitent.
1 - The Audio/Video are out of sync. Again this doesn't happen all the time, and I check the file before I burn it and the video file is sync'd. I've even burned to the HD and then re-encoded a DVD and I still get the out of sync w/ the audio/video.
2 - Sometimes I get that the disc can't fit what I'm burning? Even though it's under 4.7gb. What I've done to fix that is burn to HD then transfer, but its very frustrating.
Thanks in advance for the help.
DVD5 is 4.38 GB, not 4.7GB. The 4.7 is a bullshit marketing ploy.
NeroVision sucks the big pickle. Try ConvertXtoDVD or AVIrDVD instead. Much more reliable.Read my blog here.
Problems burning AVCHD w/Nero & IMGBurn...
By girlcreeture in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2011, 11:31 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 03:12 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 16:56 -
USING Nero TO SOLVE ALL BURNING PROBLEMS?
By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 19:18 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 16:36
