I have 37' LCD and when i'm playing a Divx movie (or any other format) i see the frame on a small square (further to the top and the bottom of the frame - the sides are black too!)
I know what a overscan is but - what is this? underscan?
how can i fix it?
Thanx!!!
Quick question(s).
What player? Example on my Phillps 5960 setting it to 16:9 Progressive resulted in the playback not filling the screen. I had two option I could set the tv to fill to stretch it horizontally or changing the TV type in Phillips setup to 4:3 and it Ok. Still didn't fill the TV as it outputs a SD signal but at least the proper Aspect Ratio.
So a possibility is you have the player set to 16:9 and is therfore not filling the 4:3 display area as a result. So that a Letterboxed Divx would have bars top and bottom (normal) and on the sides due to player settings. -
Just as a point of trivia, about 5 years ago there was a chipset in a few DVD players that did support underscan. I haven't seen a post in years about a DVD player that can do this anymore so this feature appears to be impossible to find, at least as far as I know. The DVD players that supported this used the Zoom feature on the remote control to reach the underscan mode.
If I understand this correctly, my TOSHIBA 2800 does this.Originally Posted by jman98Want my help? Ask here! (not via PM!)
If I understand what you mean by underscan many player will allow 1/2, 1/3, and 1/4 size output.
Even the inexpensive Portable DVD players hill will Zoom and shrink as will the Phillips 5960. I actually use it once in a blue moon when something is just off the edge of the screen on the TV that I am curious about.
However in the case of the OP I'm suspecting a bad encode or a 16:9 or higher video and it is a SD which would cause black bars on all four sides.
Another Underscan/Overscan Question
By yukon33 in forum Newbie / General discussionsReplies: 7Last Post: 7th Oct 2008, 18:56 -
Do hdtv owners use the "fill" mode to get rid of "underscan&
By yoda313 in forum PollsReplies: 20Last Post: 11th Jul 2008, 20:02 -
This blue paste thing
By vipertongn in forum ComputerReplies: 13Last Post: 6th Feb 2008, 08:03 -
Is there such a thing as DVD-RW DL disks?
By the_importer in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Dec 2007, 05:28 -
Unwanted 'Underscan' In Liquid Edition DVDs?
By foxbox in forum EditingReplies: 10Last Post: 30th Aug 2007, 20:07
