My card: Pinnacle PCTV Pro
I allmost given up on Vdub (the problem no is that the picture is to slow, and leaves little marks?).
Now I'm trying AVI_IO but it can't find any of my codecs (PICVidio, Huffyuv, ect.). I've tryed to install them again but with no yous? Help.
Bull,
Check out the following posts, they are similar problems to what you are experiencing.
Hope they help,
Ronin2
https://www.videohelp.com/phpBB/viewtopic.php?t=54566
https://www.videohelp.com/phpBB/viewtopic.php?t=60443
https://www.videohelp.com/phpBB/viewtopic.php?t=63487 -
Have nearly the same card Pinnacle PCTV rave and also use AVI_IO.
I use win 98 SE and with this OS you can't use your mouse to select the codecs. Instead you must use your keyboards up an down arrows to scroll up an down in the codecs menu window.
Works for me and a lot of others who use Win 98 SE.
Boink
CODEC problem
By DavidPriest in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2011, 07:39 -
my avi files only show video intermittently, not a codec problem.
By midwestcreative in forum Software PlayingReplies: 11Last Post: 18th Dec 2009, 17:55 -
DVD to AVI but no codec
By Cazz in forum DVD RippingReplies: 6Last Post: 27th Mar 2009, 10:10 -
I think I have a codec problem. D:
By Neverwhere in forum Newbie / General discussionsReplies: 6Last Post: 24th Jan 2008, 17:02 -
codec problem...
By cwb in forum EditingReplies: 6Last Post: 16th May 2007, 12:29
