I have a Pioneer 111D thats burns great at 4X. I've always used 4X blanks until now. I just bought a 100 pack of SONY 16X DVD-R and when i use DVDFab it fails to write at 16X all the time. If i slow down my burn on NERO to 4X it works great. Anybody know what the problem could be?
Thanx in advance for any help.
Several possibilities:
You are using a 40 Conductor IDE cable, which may effect the speed of some drives
Your drive is in the Slave position on the IDE cable. Some drives seem to perform better in the Master position
Your drive has reverted to PIO mode. Not as likely, as it would probably only burn at 2X
Your drive doesn't have the proper firmware for those discs
Nero is not setting the burn speed properly. Try ImgBurn instead for the burning part
The drive needs cleaning, dirt on the laser lens
But I would try a different brand of DVD disc first, and try ImgBurn as the most inexpensive alternatives
And welcome to our forums.
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 23:04 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 09:35 -
Burning Failing in Nero 7
By Osaka in forum Newbie / General discussionsReplies: 11Last Post: 10th Sep 2007, 15:03 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 14:40
