Results 1 to 9 of 9
    Mar 2007
    Hello. I am running the latest version of Windows, Vista, on 64-bit processing. The only reason why went to a 64-bit Processing was because I herd you can convert your movies a lot faster. And since I am a video producer, I do a lot of video production and from time to time I have to convert videos to High compression formats.
    So my question is that is there any "fast" software, like ffmpeg, mencoder and other things like that for a 64-bit Operating system?
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    Are you looking for high-quality results? Then you should invest in an Avid editing machine with Final Cut Pro. But for an amateur production, those should work fine.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Final Cut Pro is for Apple Macs. Avid is an editor in it's own right.
    Surely a video producer with that high a turn over would be purchasing either a turnkey editing system, or having a professional editing suite build bespoke. You would also know what level of software was required for professional results, and not what you read from the tools section here that had Freeware written next to it.
    Frankly you sound like an amateur who is probably more interested in converting downloaded avis to DVD than doing real editing.
    However, on the off chance that I am wrong, you should ditch Vista in favour of XP for the time being, as it's video performance is much faster without all the DRM overhead built into Vista.
    Read my blog here.
  4. FinalCut Pro studio, on a mac pro with 2 30 inch monitors, dual superdrives, 750GB at least, I suggest at least 4 750GB harddrives. Max out the memory to 16GB (don't get it from apple, get it from crucial or other company it's cheaper.) for a "PRO" mac setup
    not real sure on the windows setup for avid, but Vista might cause some problems with video i'm not sure.
    Dec 2004
    Australia
    ffmpeg and mencoder both support 64bits, just not under windows.
    Mar 2007
    Crap.... okay so suppose i run a Linux Live CD on 64-bit. WOuld it work then? And where could i get the builds for ffmpeg for 64-bit.
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    faster would be a dual core x 2+ xeon system w/ 2Gb + of memory w/ win2k or winxp or win server 2003 (64) running mainconcept h264 encoder with source and final product drives being different (and both fast) ....
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    or a hardware encoder - though some can be quite pricey
    Dec 2004
    Australia
    You would most likely need to compile it yourself, which due to dependencies probably isn't that practical with a live distro. You might want to dual (triple or whatever) boot to linux.
