Hey guys,
I'm using my 37" HDTV right now as my monitor for my PC, but for some reason, I can't get the resolution above 1024x768. This is kind of odd, seeing as my 19" monitor is 1280x960 (I'm using dual monitors). HDTVs are used as monitors all the time, but how do you get the resolution higher?
Any help would be greatly appreciated.
Thanks in advance![]()
Results 1 to 10 of 10
I'm not exactly sure what the Native Resolution is...larger than this, I know that much. How do I go about telling the PC that this is a HD tv?
What input are you using? Is that input speced for full resolution?My 1080p TV supports only up to 1366 x 768 on the PC input. The only way to get full resolution is using the HDMI connection.
for some reason, when I go to where you told me to go...it says my monitor is a "Generic PnP" monitor. There really isn't anything in that screen to tell it it's a HD TV
I'm using a VGA input. Same as my other monitor. Not sure how to connect my PC to TV with HDMI.
Using my HDTV as a monitor for gaming
By Darco32 in forum DVB / IPTVReplies: 2Last Post: 31st Jul 2011, 05:37 -
HDTV box to monitor
By kanganova in forum DVB / IPTVReplies: 6Last Post: 7th Feb 2010, 01:32 -
Using an HDTV as a laptop monitor?
By Wall-E in forum Newbie / General discussionsReplies: 19Last Post: 6th Oct 2009, 16:34 -
HDTV Monitor Resize
By tombowler in forum DVB / IPTVReplies: 2Last Post: 29th Apr 2009, 14:00 -
Overscan issue w/ HDTV dual-monitor set-up
By Dratheus in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2009, 20:36
