Results 1 to 9 of 9
    Jul 2002
    My C drive is approaching 2 years old and I would like to copy it to another drive before it expires and then use the new drive as my new C(boot) drive.
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Norton Ghost or similar application will do it.
    Dec 2006
    Here,where do you think?
    IMO, don't try to copy anything from your old drive to a new one.. disconnect your old drive, install new one, install OS of choice, install old drive as slave drive ,and use as backup drive with all your apps... thats just one way of doing it.....good luck!!!!
    " Who needs Google, my wife knows everything"
    Jul 2002
    Thanks Zippyp,
    I will look into it.
  5. Member bendixG15's Avatar
    Aug 2004
    If you buy a new hard drive, the manufactorer usually supplies free programs that will copy the old hard drive to the new hard drive.
    If you wish, you can go to a manufatorers web site and see what they have for programs that you can download today.
  6. Acronis MigrateEasy
  7. Member a2j3's Avatar
    Mar 2006
    @Mysts you might try HDClone it is freeware and you can learn more and download it from here...Or what I do is backup all my programs to a cd's or dvd's....
    ~~~U WON'T KNOW IF U DON'T ASK~~~
    Jul 2002
    To a2j3,
    HDclone looks real good but for the fact that my C drive is 160gb and the maximum for HDclone is 137gb if I read the specs correctly.
  9. One of our IT guys recommended DriveCopy software to me when my hard drive was failing. It was 40 Gigs, so I don't know if it has any size requirements, you'll have to look that up online. But it did make an exact copy and worked great.
