Is it possibe to encode only the video with tmpgenc and add the audio later??
If so how??????
Just blank out the audio box in TMPGE....
I'm not sure why you would want to do that though?? -
What I meant was that unless he wanted to add perhaps a wav(if the original was a compressed audio)and then mux it as you suggest or maybe audio sync problems or audio setings changes.Otherwise the original audio should be fine.
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 13:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 10:50 -
downloading a vid from radio-canada.com, but vid isn't available for dwld
By vivimarie in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 11:48 -
losing audio when loading into vid editor..
By krohm in forum EditingReplies: 26Last Post: 24th May 2010, 08:41 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 22:09
