I found a hack listed as follows:
Alrighty, I've created a CCF file, but the sequence is either too short or too long. For example, my power ir code is:Region code hack posted by Tom, July 16 2006:
Panasonic generic regional code IR sequence
0082 0015 0089 0004 00F2 0033 0017 0010 0091 0013
You can enter these codes with a PocketPC using TV Remote Controller and making a CCF file with these codes. Or use a Palm with Omniremote. Make sure no disc in the player when entering this code.
0000 0072 0000 0032 007F 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 000F 0011 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0030 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0010 0010 0010 0010 0010 0010 0030 0010 0AAB
and my Play code is:
0000 0072 0000 0032 007F 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0030 0010 0030 0010 0010 0010 0030 0010 0AAC
If I go with the R5 or R6 in the CCF editor, the ir sequence is too long. It only remains as learned.
Any suggestions or perhaps someone else had successfully done this and might send me the working CCF file.
Thanks a ton!
~ David
merlin001_at_gmail_dot_com
Black holes were created when God divided by zero
Merlin001 Hi
I also have the Panasonic S77 and it seems like it does not play any foreign DVDs, I see you came up with a hack to unlock the region, but I didnt get how to do it, can you please explain?
I have went out of my way and boughta 250 dollar DVD player thinking it will play anything, I guess I was wrong. I wonder, my friend bought one of those cheap Walmart DVD players, those play just about any DVD.
I thank you in advance
Panasonic SA-HT940 Hack
By Moridin77 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Feb 2011, 02:00 -
? regarding the hack for panasonic dmp-bd35
By pfloyd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Jan 2009, 09:27 -
Anybody knows the hack code for Panasonic LS86?
By yuri rod in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Oct 2008, 09:23 -
Panasonic S26 hack?
By Judolf in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th Jul 2008, 08:52 -
Hack for Panasonic PT-SC650
By brunohc in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th May 2008, 10:51
