Total newbie question.. What is the difference between a DVD writer and DVD Recorder? I want to convert my old VHS Tapes and camcorder tapes to a DVD that can be watched in a regular DVD player.
Any info would be wonderful
a RECORDER is a stand-alone piece of equipment that records onto dvd the way a VCR records onto tape. a WRITER goes in (or otherwise connects to) your computer.
I am just a worthless liar,
I am just an imbecil -
I'd advise going with a DVD recorder. It will be a lot easier to use and less time consuming than recording to a PC and authoring a DVD on the PC, especially for a newbie. DVD recorders typically do a good job of exactly what you want to do.
Be warned that some old commercial VHS tapes were encoded with Macrovision to prevent copying and if you have any of those, most likely you won't be able to record them to DVD without using a TBC (Time Base Corrector). Macrovision is only a problem on some commercial tapes and is no problem on camcorder tapes or stuff you recorded yourself from TV. -
I you want a substitute for your VHS - Get a DVD recorder.
If you want to cut out pieces and edit a little, get a Hauppage capture card.
If you want to do lots of edits and cool stuff with your video, get a DV capture card like a Canopus ADVC
/Mats
how to copy from DVD recorder to external disk or blue-ray writer?
By uwacm@gmx.de in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2011, 05:14 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Panasonic dmr-e85h recorder/writer player
By BIFFtheSTIFF in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Feb 2008, 22:33 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
