MY understanding is that on all TVs less than six years old the US NTSC all region DVD will play fine on a UK DVD multi region or not for anything other than a an expert (something to do with frame speed).
Is this correct?
IS it possible to be more accurate as regards which TVs will not play properly with
I have seen lots of posts partially answering this but none completely
Larry
077347 46152
Hi Larry,
If the DVD is NTSC and Region 0 all UK players will be able to play it because Japan is an NTSC country and Region 2.
Not all PAL (UK standard) TVs produce real NTSC but most produce PAL60. The absolute worst thing that could happen is a slight stutter as the 25 frames per second catch up to the 29.97 frames per second encoded on the DVD or the DVD plays balck and white which is practically impossible.
So essentially you are right, an "all-region" i.e. region 0 DVD form the US in NTSC will play fine on most newer equipment in the UK.
Will region free DVD play on a PAL DVD player?
By perceptionist in forum DVD RippingReplies: 2Last Post: 23rd Sep 2011, 19:56 -
Convert PAL Region 2 DVD to NTSC Region-Free DVD?
By wizoomer95 in forum Video ConversionReplies: 6Last Post: 6th Aug 2011, 21:10 -
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 05:39 -
Ntsc BluRay players play PAL(region-free) dvdr?
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Nov 2009, 18:48 -
Region 1 dvd, ntsc, pal
By sonydvd in forum Newbie / General discussionsReplies: 6Last Post: 30th Jan 2008, 08:58
