moin, moin...
I've read a lot of stuff by now,
but it seems, there is no codec
I can use from within Vdub.
Please proof me wrong and tell me
that there IS one, that can compete
with TMPGenc, because life would be
much easier for me, if I hadn't to
use both.
TIA....
scholly
Sorry, Virtual Dub can only read MPEG-1 files, it cannot write or encode them.
it is possible with DVMPEG it shows up in Vdub as a codec.
In Avery Lee's FAQ he mentioned that
"When DVMPEG brings up its modal configuration dialog box, which blocks input to dialogs underneath it, the dialog sometimes inexplicably appears behind VirtualDub's main window. You can try hitting Alt-ESC to push other windows back to try to get to the dialog. Incidentally, Internet Explorer 5 messes up ALT-ESC under Windows 98, so you may have to minimize or close IE5 windows to do this."
but it's just mpeg1
jj
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
GOP control in ffMPEG MPEG1 encoding
By Computer Nerd Kev in forum Authoring (VCD/SVCD)Replies: 12Last Post: 4th Jul 2011, 03:52 -
can i truncate mpeg1 video files without re-encoding?
By dullrazor in forum Newbie / General discussionsReplies: 2Last Post: 22nd Nov 2009, 16:47 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 15:11 -
Aspect ration problems when encoding in VDub
By sd_smoker in forum Newbie / General discussionsReplies: 12Last Post: 5th Jul 2008, 12:24
