Results 1 to 15 of 15
  1. Member Tbag's Avatar
    Mar 2006
    how can I make photos look like this using photoshop?
  2. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    You can't. That graphic was probably done in a draw program which uses only linear lines as opposed to Photoshop which uses only bitmap pixles and edits that way. Adobe Illustrator or Corel Draw will create in the style you want, but believe me it's not easy.
    The closest that I can suggest using Photoshop is to use the selection lassoo to select the head, then open the Brightness/Contrast filter; slightly darken the brightness (not too much), then tweak the contrast higher until you get to where you want it. Again, it's nowhere near what you are looking for, but that's the best I can suggest. After you tweak it as close as possible, try different filters in Photoshop to see if you can tweak it closer.
    Sounds like a fun project.
    USA
    Sorry, didn't have any people photos available. I boosted up the brightness and contrast and the saturation to blow out the detail, blurred a little, then use the 'Cutout' filter. There may be a 'posterize' filter that would work better:
    The original:
  4. Member Tbag's Avatar
    Mar 2006
    nice ^^^^
  5. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I don't have Photoshop but if I was trying to recreate that affect I would first do a edge preserving blur to eevn the colors out. Save it as a .gif with a reduced color pallette.
    Here's a quick example, saved at 10 colors:
    That's probably about how they accomplished it, if you look at the nose you can see som spots of color. If you're famialar with working with a gif pallete you should be able to to crete a better image that the one I posted creating a custom pallete.
  6. Member Cornucopia's Avatar
    You can do that in Photoshop.
    Use your lasso (magnetic if you need it) and then create paths from your various selections. Paths are vectors, just like in Illustrator. These paths can be used as masks/selections.
    With masks active, FILL the various sections with the appropriate choices from you reduced color pallet.
    Since you're still working in Photoshop, ultimately you're still stuck with a bitmapped image, so you DO NOT want to resize AFTER filling in. If you have to, resize to your final desired size before doing anything (otherwise, you'll blur/smear the edges/transitions).
    edit: What thecoalman did is quite similar to "Posterize" ( [Image | Adjustments | Posertize...] ).
  7. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Taking it a step further after converting it to gif and reducing the colors convert it back to true color and apply a gaussian blur to to smooth out the edges. Note that all these images have been reduced in size from the ones i was working on...
  8. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    That's the first thing i went for in my image editor but the options are limited and it didn't work very well in my editor.
  9. Member Cornucopia's Avatar
    Here's what I did quick-n-dirty. You can do alot better if you make layers first, refine your selections first, etc.
    Dec 2005
    hi,
    Now I am just really learning myself on using photoshop and I have a ways to go.. many time knowing what the orginial picture looks like determine what technique/procedure to use..
    in this picture I would venture to say , first maybe several several layers and
    a combination of masking things off and using the color sampling maybe and the brush... maybe some hue saturation...
    if you want really want to learn from people are really good with photoshop, and these guys are good.... take ride over to http://www.retouchpro.com/ , they have a very active forum and there willing to help, also there a lot of tutorials avail on there site that you might find very usefull..
    the group there is always challenging each other and h elp out us newbies on the various techniques and usage of tools....
  11. Member Tbag's Avatar
    Mar 2006
    thanks for the link i'll check it out ^^^^^^
  12. Member Tbag's Avatar
    Mar 2006
    that looks very good, can you dumb down the explaination on how you did it if its possible
  13. Member Conquest10's Avatar
    Chicago, IL
    The best way to do that would be to draw it in Illustrator. In Photoshop, there is a quick, dirty way to achieve a similar look using the cutout filter.
    His name was MackemX
  14. Member Cornucopia's Avatar
    Going from memory...
    1. Load picture
    2. Make selection (with wand, lasso, rect, color select, etc)
    3. [Paths tab] click OptionsMenuArrow(in corner) Make Work Path (with ## pixels of tracing tolerance)
    4. Make new layer
    5. Choose new foreground color
    6. Back to Paths tab, work path should still be there
    7. Fill with foreground color
    8. Repeat 2-7 for each "object" you want to have a separate color for.
    That's all I did (of course, I forgot to use layers, but I was in a hurry).
  15. Video Restorer lordsmurf's Avatar
    You can also turn the image into a high-res video, use a "cartoonizer" type video filter, then extract a still from the encoded video (the video is probably just 1 frame anyway).
