Hello, Friends!
I'm new here. And I've got some questions about multi-angle DVD processing. So
1. When I'm demuxing a multi-angle DVD into streams I seems to have corrupted audio streams, while video streem seems to be ok. As far as I understand this is the way how Multi-Angleing is done. But when I mux those back again I have the corrupt whole media information. And there's problems with subtitle syncronization with this corrupt audio.
So, Is there a detailed guide how to add subtitles to a multi-angle DVD and then mux it back keeping Multi-Angle?
	I have the same problem. I got the Ghostbusters DVD. Alas, although bought in NL and is states to have Dutch subs... no sir. Not on the disk. But when ripping and demuxing, adding the dutch subs and remuxed:
 IFO Edit: error
 Muxman: error
 VobReMake Pro: no way to add or replace subs
 PgcEdit: no such way...
 This is a DVD9 and want to keep it that way, just add the Dutch subs - which should have been on there form the start!
 So, I second the call of Mr. cruel!
 Dozo
	Don't confuse multi-angle with seamless branching. They are different beasts. Multi-angle only has one audio track that services all the video angles. Seamless branching has different sections of audio. Very few rippers/demuxers handle multi-angle titles well. And even fewer will put them back together again. DVD Decrypter and DVD Shrink can be told to rip a single angle, which makes subsequent processing much simpler. Read my blog here.
  How to compress the DVD with multi-angle feature?By UMO in forum Newbie / General discussionsReplies: 7Last Post: 22nd Mar 2010, 23:14
  Mixed Multi Angle DVD Encoding ProblemBy werdna1900 in forum Video ConversionReplies: 3Last Post: 11th Jun 2009, 05:32
  Backup a multi angle DVDBy src2206 in forum DVD RippingReplies: 1Last Post: 9th May 2009, 01:34
  Multi-Angle DVD-9 to Single-Angle DVD-5 helpBy rayden54 in forum DVD RippingReplies: 6Last Post: 11th Sep 2007, 21:44
  Multi angle - dilemmaBy flipzoso in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 03:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
