Hi all
I would like to convert from a DV file
http://www.users.on.net/~mark/169.jpg (30k)
to a 4:3 file with black bars.
http://www.users.on.net/~mark/43.jpg (7k)
Can I do this in one step with ffmpegx or another app?
Yes you can with ffmpegX:
Drop your file for input. Set an output filename (foo.mp4) and location. Pick a h.264 preset. In the Video tab, select the H264 [.MP4] (ffmpeg) codec to allow custom letterboxing. Set the target video width to 320. Set Autosize to 4:3; this will fill in the height (240). Use the Best button in the bitrate calculator to get an appropriate bitrate. Now change the video height to 176 pixels to get the wanted aspect ratio. In the Filters tab, select Deinterlace, as your likely converting from interlaced to non-interlaced. Set letterbox to [32,32,0,0] to get the black bars on top and bottom. In the Options tab, Encoding profile can be 'No profile' or 'PSP'. Encode.
Adding black bars
By ebay in forum Video ConversionReplies: 4Last Post: 7th Aug 2010, 05:37 -
Black Bars
By cinnamonhearts2 in forum Newbie / General discussionsReplies: 15Last Post: 30th Jul 2009, 13:44 -
black bars or not?
By Cowabunga in forum Video ConversionReplies: 6Last Post: 16th Apr 2009, 13:56 -
Flash FLV Internet Video Larger than 320 x 240
By foochuck in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2007, 12:49 -
I can only capture at 320*240!!
By MisterBubbles in forum Capturing and VCRReplies: 1Last Post: 13th Jun 2007, 22:36
