Video: DivX 5 512x308 25.00fps [Video 0]
Audio: Vorbis (deprecated) 48000Hz stereo 112Kbps
Is there an easy way to convert the following to DivX with MP3? This can only be opened in VirtualDubMod, which does not have a way to save the WAV file.
Thanks!
Technically you have an ogm or you were just referring to the audio?
VirtualDubMod "should" be able to recompress the audio to mp3 and resave to avi in one go, although it doesn't look like it will actually do it.
mencoder works with -ovc copy -oac mp3lame
not sure if -mc 0 and -vf harddup work with -ovc copy or not though (makes sure that frames don't get dropped).
You could also try avidemux. -
Demux Vorbis with VirtualDubMod to myaudio.ogg - using Demux button then convert myaudio.ogg to myaudio.mp3 (CBR recommended) using foobar2000. Finally remux myaudio.mp3 with the video using VirtualDubMod (don't forget to disable Vorbis).
CMIIW
how do you convert .ogg audio file to mp3?
By shun in forum AudioReplies: 5Last Post: 22nd Sep 2023, 16:34 -
How to convert .BUP and .IFO to AIFF, AU, FLAC, M4A, OGG Vorbis or WAV
By MLK3329 in forum Video ConversionReplies: 6Last Post: 5th Oct 2010, 21:13 -
Problem with BeSweet/BeLight. Trying to batch convert Ogg Vorbis to ac3.
By rayden54 in forum AudioReplies: 9Last Post: 30th Dec 2008, 19:37 -
Help: How to convert .rad to other format (mp3/wav/ogg/etc)?
By Nator in forum AudioReplies: 1Last Post: 11th Sep 2008, 21:06 -
How do I convert .MP3 to .OGG directly?
By Cobra in forum AudioReplies: 11Last Post: 9th Oct 2007, 15:04
