I've noticed over time that my dvd burner has slowed considerably.
as we talk i'm burning a movie using dvdplatinum and it's burning speed is 1.5x. i'm using dvd-r verbatim disc and a maxtor 160gb hard drive/philips dvd+-rw dvd8801 burner. it takes like 30-40+ mins to burn a dvd.
i've cleaned my hard drive, defraged it, ccleaned it, and adaware cleaned it also and still nothing changes.
is this normal and if not what can i do to remedy this problem
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
To check DMA/PIO mode within Windows:
Control Panel>System>Hardware>Device Manager>IDE ATA/ATAPI controllers.
From there, right click on one of the channels and choose 'Properties>Advanced Settings'. All drives should be DMA mode. The 'Current Transfer Mode' for Hard drives is usually DMA 4-6 and DVD burners DMA 2-4, DVD ROMs usually DMA 2. If you see any in PIO mode, that can slow things down.
Changing them back may be easy or complicated. First see if you can change them in that window. If not, I usually uninstall the channel the drive is on and let the OS reinstall it. This will usually take a reboot. This will not damage any files on the computer. If it's still PIO, see if you can change it now.
From there, if no luck, get back to us.
DVD Burning causes Extremly slow playback
By PowerFalcon in forum DVD RippingReplies: 4Last Post: 27th Aug 2011, 16:47 -
Dvd slow burning
By Psco2007 in forum Authoring (DVD)Replies: 29Last Post: 8th Dec 2010, 16:09 -
DVD ripping/burning very slow
By happy.hrvat in forum Newbie / General discussionsReplies: 5Last Post: 1st Apr 2008, 18:24 -
burner too slow
By birdcat in forum DVD & Blu-ray WritersReplies: 8Last Post: 1st Feb 2008, 23:32 -
Sony DRU-820A DVD Drive suddenly burning slow
By progrocktv in forum DVD & Blu-ray WritersReplies: 3Last Post: 24th May 2007, 22:55
