HI,
I've been having problem with my dvd shrink program crashing at various times. For instance it will make it to 50% of the encoding stage on the movie casino then crash and my computer will simply turn itself off, the same thing happens on the count of monty cristo only that one makes it to 62%. Now i've used ripit4me to get the movie off the dvd and used fixVTS program on the ripped files. THen i use dvd shrink for the rest of the process, but it still crashes everytime at the exact same percentage completed. I've tried disabling the nero burning option in dvd shrink and also not watching the video preview while it is encoding but nothing has worked. If anyone has any ideas and how to get around this problem i would really appreciate it. Thanks
DVD Shrink is a resource hog. It sounds like your pc is overheating.
Try to close as many programs running in the background as you can. -
just for the heck of it, try ripping with DVDFabdecrypter. Cant't hurt ,and it's worked for me,when R4ME fails.... good luck!!!!!
but it's rare when it fails.....
" Who needs Google, my wife knows everything" -
Yup my computer was simply overheating, after i posted that i loaded up speefan and it was peaking at 76 degrees C, and then just shutting down, guess the old heatsink/fan isnt what it used to be. But thanks for the help guys.
Can't shrink "Predator 2". Any ideas?
By burgurne in forum Blu-ray RippingReplies: 6Last Post: 18th Dec 2010, 16:53 -
Problems backing up DL dvds using DVD Shrink and ImgBurn
By ManuBumb in forum Newbie / General discussionsReplies: 9Last Post: 7th Apr 2009, 21:35 -
Will using the pc while using DVD shrink cause problems to editing????
By jones24 in forum DVD RippingReplies: 8Last Post: 7th Oct 2008, 10:39 -
problems with DVD Shrink 3.2.0.15
By janefield in forum Newbie / General discussionsReplies: 6Last Post: 25th Aug 2008, 07:20 -
dvd shrink problems
By anahata3 in forum DVD & Blu-ray WritersReplies: 9Last Post: 9th Jul 2007, 11:07
