Well, with the new computer about to arrive I need to ask this.
Should I keep using my "old" Sound Blaster Live, very similar to this one (http://www.soundblaster.com/products/product.asp?category=1&subcategory=207&product=14184) or should I use the onboard sound from the mobo that I bought, wich is an Asus P5W DH Deluxe (http://www.asus.com/products4.aspx?modelmenu=1&model=1198&l1=3&l2=11&l3=248)?
I know onboard audio is much better nowadays but, as I won't use the coaxial outputs from the card, neither 5.1 from my Sound Blaster, I don't know if it's better to change.
Also I don't use the line in from the card on my captures, I have a Hauppauge PVR500.
Caple
The onboard audio on that ASUS is good enough. You will also have one more available PCI slot in your computer. Go with the motherboard audio.
discrete sound card vs onboard quality
By mammo1789 in forum AudioReplies: 1Last Post: 17th Dec 2011, 07:53 -
Sound Blaster Titanium Fatal1ty Pro
By MR 3 in forum AudioReplies: 2Last Post: 16th Sep 2010, 11:49 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 14:44 -
Live sound effect?
By tarasha in forum AudioReplies: 1Last Post: 10th Jan 2008, 11:07 -
ExpressCard Sound Blaster X-Fi Xtreme Audio Notebook
By AuroEdge in forum AudioReplies: 0Last Post: 7th Oct 2007, 01:14
