Each time I launch FFmpegX, it prompts me for the location of two files, "mencoder" and "mplayer."
I have these files under /opt/local/bin as I got them from DarwinPorts, and FFmpegX works perfectly once I point it to their location, but it forgets where they are each time I quit and relaunch.
Am I doing something wrong here, or should I not have used DarwinPorts for the mencoder/mplayer files, or...?
Thanks for the help. I appreciate it.
ffmpegX checks on launch if the binaries are present and of the right version. Your version of the binaries is possibly different from what's expected and it doesn't pass this test. That's why it keeps asking.
Do you have any special reason to use other binaries than the ones suggested by the author?
No particular reason, I had downloaded mplayer via DarwinPorts before I started using FFmpegX. When I downloaded and installed FFmpegX, I did so with the intention of experimenting with it later, and remembered only that there were "certain plugins required." Didn't recall exactly what they were, but I figured I'd have to go and download them.
When "later" came around and I decided to play with FFmpegX, I discovered that I already had the plugins in question--got them way back when, from DarwinPorts.
Anyway, you're saying I should try the devs' recommended version then? Will do, here's hoping.
Thanks a ton, I do appreciate the help.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
ffmpegX won't convert files due to "syntax error near unexpected token"
By JayEm in forum ffmpegX general discussionReplies: 1Last Post: 15th Feb 2010, 17:26 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 21:55
