http://cgi.ebay.com/5-1-Sound-card-USB-Audio-Microphone-Adapter-Virtual-NEW_W0QQitemZ3...QQcmdZViewItem
Has anyone used an adapter like this for a laptop? I only have mic input on my Toshiba Satellite. No line in. I've only had time to test a bit and there seems to be too much noise when recording via mic. I know that when I use a USB headset for listening on my PC I get no noise and when I hook earphones to the PC I get a bunch of noise and interference. I was wondering if this device might kill extra mechanical noise or interference.
I just bought one of those as well. No issues, Windows XP picks it up as a sound card. I have only used it for Headphone's no Noise with just listening...
I hooked up the USB headest to my laptop and there is no noise. I guess it's just listening through normal earphones they get a lot of interference.
Hey... props to you for that auction link.. i've been looking for something like that for a while now..can't beat the price... i am converting my vinyl collection to CD.. will make it much easier.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Unless I am missing something, there still is no 'line-in' on this adapter. There is a microphone input, but more than likely, that is mono... not stereo.
Edit: This would offer stereo recording:
http://cgi.ebay.com/New-USB-2-0-Video-Audio-Capture-Adapter-Card-DVD-Editor_W0QQitemZ2...QQcmdZViewItem -
It turns out I was jumping the gun. It may just be the particular earphones I was using. They are Shure E2C IEM's so they are not crap. For some reason when I listen with them I hear noise. I used my USB headset and it's perfectly quiet. With my Sony ECM-MS908C mic hooked into a Sound Professionals preamp @ +50dB plugged into the mic port using my USB headset I was recording sounds from another room in the house and the only noise I heard was ambient sound. This is all I've had time to mess around with so far. Over the next couple weekends I'll be running sound for a local bluegrass act and will have the chance to record some live stuff.
What usb wireless N adapter to get?
By neworldman in forum ComputerReplies: 2Last Post: 3rd Nov 2010, 08:49 -
Laptop, Xbox 360, USB Sound card and Z-4
By AXGTi in forum AudioReplies: 3Last Post: 1st Oct 2010, 09:50 -
Wireless usb adapter on WD TV
By kyrcy in forum Media Center PC / MediaCentersReplies: 2Last Post: 19th Apr 2010, 17:50 -
USB to DVI Video Adapter?
By lenny_67 in forum Media Center PC / MediaCentersReplies: 0Last Post: 19th Mar 2010, 11:24 -
Nintendo USB Wi-Fi adapter
By Xylob the Destroyer in forum Off topicReplies: 13Last Post: 3rd Sep 2007, 13:10
