I created a DVD using GUI_DVDauthor (which is a nifty program) and it looks fine, but the audio cuts in and out just about every second. I played the resulting VOB files directly (with Nero ShowTime) and both the video and the audio are fine that way. Then I point Nero ShowTime at the VIDEO_TS folder, and it brings up the menu correctly, but the sound cuts in and out. The burned DVD also exhibits this behavior.
Since the VOBs are fine, what should I look at to correct the problem?
Have you just tried play with nero crap showtime?
Tried on a standalone dvd player?
What audio format are you using? dolby ac3,mpeg or wav/pcm?
Audio stutter when encoding using Megui
By dc0yy in forum Video ConversionReplies: 0Last Post: 2nd Sep 2011, 12:19 -
audio/video stutter delay in VLC & MPCHC
By skorpinok in forum Newbie / General discussionsReplies: 1Last Post: 31st Aug 2011, 10:51 -
Canopus ADVC110 w/Power Director audio stutter problems when capturing?
By popflier in forum Capturing and VCRReplies: 7Last Post: 6th Mar 2010, 04:48 -
Fix For Audio Stutter and Gigabyte EP35 DS3 Boards
By DarrellS in forum AudioReplies: 5Last Post: 15th Oct 2008, 05:55 -
video stutter due to audio?
By rallynavvie in forum AudioReplies: 3Last Post: 29th Mar 2008, 14:19
