Hi
What is the best and most powerful software for converting 3GP to AVI or MPEG?
Thanks for any help in advance.
Sean
ffmpeg (or together with a gui like super,mediacoder,winff)
Thanks for your help, these applications are free, could it be a reason for introducing them as best ones? If we do not want to consider the money, what would be your answer?
they are free, try each one, on the same video and use the one you like best
Some of the pay programs that do the same conversions often use the same freeware programs and get the same results. But they charge you for those freeware programs that are just hidden a a different wrapper.
As mentioned, try a few of the freeware ones with a sample clip. If you can find some trial versions of the payware programs, try them also for comparison with the same clip.
H264/AMR file in .3gp format
By Jean777 in forum Newbie / General discussionsReplies: 1Last Post: 8th Apr 2010, 15:02 -
3gp to most universal format
By rokeeffe in forum Video ConversionReplies: 5Last Post: 6th Feb 2010, 15:12 -
winfastpvr application/ Capture Format problem
By bibimaryam in forum Newbie / General discussionsReplies: 6Last Post: 28th Apr 2009, 08:57 -
How to cut a 3gp file to part files without a format change?
By kop in forum Portable VideoReplies: 1Last Post: 22nd Oct 2008, 12:52 -
Converting Streaming Video Format(s) to 3GP --> Any Advice & Suggest
By SnakeGirl in forum ffmpegX general discussionReplies: 0Last Post: 21st Jan 2008, 08:21
