  1. Hi All,
    I'm looking for an AVI to MPEG Converter that allows you to adjust the brightness of the output file. I find that some of the AVIs I download are too dark. I was using Cucusoft's AVI to MPEG Converter Pro (v 4.29) for this purpose but now it's giving me grief about not being able to find the codecs (even after updating the codec database). Version 4.29 seems to be the only one that allows you to adjust the brightness (later versions don't have this feature). Is there a program someone can recommend that offers this feature?
    Thanks in advance,
    - Bodrey
  2. Member daamon's Avatar
    Melbourne, Oz
    Adjust the brightness in the AVI, re-save to AVI and then encode. There are plenty of video editors around that will adjust brightness in an AVI - have a look through the Tools section for one that suits you and your budget.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
