hi all...i have a Sony RDR-GX330 settop dvd recorder. now i record things off of my television like music performances and some shows. i use dvd decrypter to rip the recordings to my hard drive so i can do things like cut out commercials, add fade in/out etc. i also record at the highest quality so only 1 hour of video is available on a dvd+r. i would like to fit around 2 hours on a dvd so i use CCE SP to re-encode the video.
what i would like to know is what settings should i use in CCE if my recordings are NTSC 720x480 interlaced. should i use top field first when re-encoding? and are there any other settings i should use? thanks very much for any help.
also should i use dvd2avi or dgindex when creating the .d2v file and should i be set to pc or tv scale when doing it? thanx again.
Results 1 to 1 of 1
Looking for Hard Drive recorder, with DVD burner
By subc in forum DVD & Blu-ray RecordersReplies: 8Last Post: 30th Jul 2010, 17:08 -
Looking for a DVD recorder with hard drive
By sldvd in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Jun 2009, 10:30 -
dvd recorder with hard drive?
By chuckliddell101101 in forum DVD & Blu-ray RecordersReplies: 31Last Post: 24th Jan 2009, 18:51 -
DVD Recorder vs. Hard Drive
By docref in forum DVD & Blu-ray RecordersReplies: 9Last Post: 14th Aug 2007, 01:27 -
Buy DVD Recorder w/ or w/out a hard-drive?
By csmith in forum DVD & Blu-ray RecordersReplies: 8Last Post: 15th May 2007, 03:55
