When i try to join two .avi files there is a problem... the file joins but there is only half of the second file, sometimes it cuts off, and sometimes it carries on playing but the counter stops. And when i convert to dvd it stops where the counter stops.
I've tried making the name shorter and removing numbers and symbols as i've heard that can be a problem, but it's still happening. Does anyone know of this problem and a solution.. I've reinstalled ffmpegx and the binaries but the problem is still there. It doesn't do it all the time just on every 5/6 file and only on certain files, for example it won't not do it once then will work on second attempt.. It happens every time with some files and never with others
What codecs are being used in the .avi files?
are they both the same?
What happens if you join via copy/paste in Quicktime Pro?"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
to be honest i don't have a clue about codecs, i couldn't tell you, but they are the same type.. i'll downoad quicktime pro and find out, cheers for a point in the right direction....
Right, tried it in quicktime pro... i keep the lentgh of the film but lose the audio.. which is ac3 if that matters -
ok, ac3 requires the proper codec to be installed in Quicktime PRO. Try that with it installed, you should then be fine.
Urban Mac User
Resizing and joining two avi files and keeping file size down
By wayc00lio in forum Newbie / General discussionsReplies: 5Last Post: 16th Feb 2011, 10:18 -
How do I solve this file joining problem?
By A_Shepherd in forum EditingReplies: 30Last Post: 2nd Sep 2010, 13:27 -
Is there a max file size when Joining avi files.
By admjim in forum ffmpegX general discussionReplies: 2Last Post: 14th Feb 2010, 03:41 -
ASFBIN and Movica : Batch File Joining Possible ?
By Alterego in forum EditingReplies: 0Last Post: 12th Oct 2007, 03:18 -
I'm new to Joining multiple avi files into one big file....
By Lahori82 in forum EditingReplies: 4Last Post: 29th Aug 2007, 13:05
